I need some help with adjusting my carb. I have tried the classical approach...tighten mixture screws, back them out 1-1.5 turns and then slowly adjust until the motor starts to stumble, ect. I know that on some carbs, the direction you turn the screws differs. I have tried both ways and nothing seems to help. This is my first encounter with carb problems so I am not sure if the mixture is LEAN or RICH. Here are the details:
350 SB Chevy, 600cfm Holley (I think its a newer one it has gray bowls)
Black soot in the exhaust.
Strong exhaust odor
Fills garage with hazy blue-ish "smoke"
the car seems to be running fine, but because of the excess exhaust discharge I must be RICH or LEAN. Any suggestions out there???
Strong exhaust odor
