I'm far from an expert, but here's my $.20 worth....My personal preferences for your 307 would be a Holley 600 cfm or Carter/Edelbrock 625 cfm (Summit lists the Carter as 600 on manual choke & 625 on electric choke). I lean a little more toward the Carter for a smooth, non-leak streetable application out of the box & day in-day out(Note:Edelbrock carbs are basically the same as the Carter). Both the Holley & Carter are vacuum secondaries so they should work good with the "glide"(kick-down, etc.). I also prefer a dual plane manifold like the Performer RPM (for square bore carbs I suggest)or a Weiand Stealth. These provide good low-end & mid-range power vs. a single plane "dump" manifold committed to high RPM. Holley also has a 450 cfm carb that would work sweet on the 307, but it's kinda pricey compared to the other carbs I mentioned. You might consider contacting Holley &/or Carter (Federal Mogul owns Carter)for their recommendations on your specific setup. Fire back with what you end up with & how it works. Good Luck.
