As Todd stated the entire suspension is codependent and interdependent.
Take your Jack Stands and set them as "short" as possible. Park your car on a level surface. Use your Floor Jack to jack up the right front, remove the wheel/tire, and let the right front frame down onto one Jack Stand (which is placed just behind the right front wheel well). Then do the same with the left front.
BE CAREFUL. At this point both your front wheels/tires are off and the car is resting on the frame and the Jack Stands -- by doing this you've removed the front suspension from the equation: your front suspension can no longer affect how the rear suspension sits. Now measure the distance from the floor to the top of the
REAR wheel wells. If the distance is the same then your problem is with the front suspension. If the measurement is off then fix the rear suspension problem first: Check the isolators and replace them as necessary. You can try swapping the springs from one side to the other side. You can replace the springs and as a last resort you can try adding an extra isolator to the low side.
BE CAREFUL: use another set of Jack Stands under the rear frame while you're working.
Once the rear suspension is level you can start on the front suspension problem. Put your wheels/tires back on (drive the car around the block) and measure the front wheel wells. If there's still a problem check to make sure the springs are seated properly, also check the isolators and replace them as necessary. Try swapping the springs from side to side, and try adding an isolator to the low side.
As Bob stated DO NOT tighten up any of the suspension bolts until you're done adjusting the suspension.
Good luck.
