My problim with the 69 Dart is The left tail light and left front signal light are bright and flash right.The right side front and back are very dim.I unplug the rear harnes and put my test light to the conector by the kick panel and the right side from there is weak.What could be the problim and were should i go from here.also as it should the brake lights are bright when i test each terimal at the conecvtor.thanks for the help.man replys at Mopars are very slow.
http://home.talkcity.com/sparkplugst/snakepell/index.html 66 396 Beaumont.
Once bitten twice shy.
Don Pell 66 396Beaumont.
