Well I set the engine in the car, put the motor mounts through and tightened up the tranny bolts. When I went to put the nuts on the motor mount bolts, I noticed that one of the bolts were stripped. I took it out and got a new one. Now I can't get the new bolt in!! It will go in the front side but not the back. Any sugestions?? The hole on the back is off quite a bit. I tried moving the engine around but it just isnt' working.
