I can't find the cast number on my engine for the life of me. I recently bought a 66 Chevelle and I believe it has a 327 in it. The oil filler is in the fron on the intake. I have looked every where for the cast number. On the passenger side front there is a spot where i read it should be, but there is nothing! I searched the back of the motor and still nothing. Do I need to pull the motor to see the cast number? Please help!
· Super Moderator
Devin
There is a difference between the "casting number" and the "engine code" which is what I think you are looking for. If you are looking for the engine code, which will tell you what kind of car or truck the engine originally was installed in, then look at this site for some pictures:
http://www.nastyz28.com/chevy-engine-code-stampings.php
If the area where the code should be is blank, there is always the possibility that the engine has been remanufactured and the top suface of the block was remachined to make it flat. This will cut away the numbers.
If you are looking for the "casting" number, it is typically on the flat surface right behind the drivers side cylinder head. Some are also on the passenger side. You should be able to see it from above by looking down at the back of the engine right in front of where the transmission bolts up. This number really does not tell you much as the same casting number block was sometimes used for many years.
Hope this helps,
Thanks this is good info; however, i still can not locate the engine code. I can't see anything on the back drivers side. Where exactly is it.. This is so frustrating! I want to know what iks in my car!
· Super Moderator
Devin,
If the block has been remachined, you will probably not be able to exactly identify the engine. The casting number should be very easy to see unless it is so covered with grease and dirt that you cant read it. Look at the picture on the upper left in Mike's post. Slow down and you will find it :)
