Hi y'all,
I just got a 68 Chevelle that seems to have been built for week-end track racing. It's got a 383 stroker, brodix heads/roller cam & rockers, single plane hi-rise w/Demon 750, built 200/really H.D built rear-end w/posi .410, ladder-bars,boxed control arms.
The seller didn't pass on much info as to what he built it for. It has quite a lope & seems to like higher RPMs, it definitely is jetted too rich, anyways it pings under certain loads, diesels on shut-off. I always use good gas so I figured over-timing was the culprit. I checked & it was off the timing tab which goes to 18 degrees, I backed it all the way to 12 & it would sputter, die, back-fire but pinged less, I tried 14,16, 20+ degrees, but can't find a sweet spot! Its got a full MSD control, rev limiter, coil & pro-billet distributor. I'm not familiar w/this setup, can the control box be adjusted, or does it have pre-set curves? It runs strong, but I know its not close to what it could do. I thought those older MSD modules had a algorithm ability or is it only the newer generation? Eitherway, I sure would like to hear some thoughts about this...
thanx, Alan
thanx, Alan
