1 - 20 of 20 Posts
I have a couple of u-joints that need replacing. The problem is my car, 69 Chevelle, is not stock and need help with a new set of u- joints.
The dimensions are, outside to outside = 3 1/4", diameter of caps is 1 1/16".
Transmission side used two inner clips on the yoke end and two outer clips on driveshaft end. I have a ST-10 transmission.
Rear u-joint has outer clips. They are around 40 years old by the way.
Edit: if squeeze the caps together outside to outside is 3 7/32".
Household hardware Nickel Metal Fashion accessory Titanium
Auto part Household hardware Metal Fashion accessory Titanium
Discussion Starter · #3 · (Edited)
Thanks SFD, the chart measures right when I use the Outside lock chart but when I measure the grooves like they say to for the inside lock joints, nothing matches up.
Outside of grooves measurement is 2 3/8", inside of grooves measurement is 2 3/16". The inside lock cap measurements are also different.
I need a 1310 with grooves in the right spot.
They kind of resemble Lakewood u-joints, I hope not, Lakewood u-joints are $90 each Canadian.
With the caps removed, do both sides of the cross measure the same?
If your still having trouble I used 2 different size caps, same ID different OD
I'll post a pic of the Neapco I bought 9-10 yrs ago, US made but dont know about now, I used the US Im having a phone problem posting pics but theyre diss model #s
Rectangle Fixture Font Gas Wood
Discussion Starter · #20 ·
Go to any Napa store. Have them grab their catalog for u-joints. They can measure the old one and in the combination u-joint section they will come up with it.
Thanks MrGardman, I did that with my local parts store, they can get the Neapco ones. I will probably get the Moog ones, made in USA, I can get them online here in Canada with free shipping. Had no luck with the Spicer brand here in Canada either.
1 - 20 of 20 Posts
