1 - 12 of 12 Posts
guys,
can i use RTV to seal the various pipe plugs on my big block (dart m)?
if i have to get something else i will, just want to know if its ok to use RTV.
thanks
jeff
· Super Moderator
The rtv can ease its way out over time with heat stress pressure. I would use liquid teflon or teflon tape.
· In Memoriam
I've been using RTV on pipe plugs and freeze plugs since it first came out, what's supposed to be wrong with it? I don't think there's any oil or water pressure in an automotive engine that can push cured RTV out of tapered pipe threads. I don't think 10 (ten) times the pressures seen in our engines would hurt that stuff.
Discussion Starter · #8 · (Edited)
ok guys, i got some good thread sealer. now, how do i know how tight to get them? do i need to make them flush with the block? im using a rachet with an allen head socket, so i have enough leverage.
thanks guys
Do not over tighten you will crack something
Yeah, pipe plugs use tapered threads. I just use teflon tape. Make sure to wrap it in the right direction, if you don't, it will just unwind itself when you thread it together. Then, after it's together, I peel all visible tape back off, makes for a very nice and clean setup! :D
1 - 12 of 12 Posts
