G
It's a 1988 model unit, so probably from a 3/4-1 ton truck. Possibly a van.
Don't take it to the dump...
Give it to a needy car enthusiast. If the case is good, the core is worth $50-150.
The Chevy cases are getting harder to find.
Can anyone tell me what this tranny is, it's supposed to be a 400 the tag reads 306
88 LBA - 8092
Thanks for any help.
I will bet, it came from a big block truck in 1988.....
I have a Turbo-400 that came from a 1986 3/4 ton, 4 door, 4 wheel drive, w/454/ th400/ 3.73 rearend.....
The numbers on it are [ 079 ] [ 86 FPA - 11669 ]....................................Don.
If the trans output shaft is drilled/tapped it is from a vehicle with a two piece drive shaft (drive shaft w/hanger bearing) with a bolted on yoke. The ones I've seen like this also have a deeper pan.
I've read that some people use them with a slip yoke but I'm not sure that's a good idea.
If the trans output shaft is drilled and tapped it is from a vehicle with a two piece drive shaft (drive shaft w/hanger bearing). From what I've read, this type of output shaft isn't the best for high hp cars because the yoke doesn't slide on the output shaft as far. I'm pretty sure the rest of the trans is OK.
Thanks guys', I'll give it to someone if they need it. Mike
