I have a GEN VI 502 freshened up bottom end new rings, bearing, etc.. Edelbrock 290 oval port heads milled to 100cc to get roughly 10.5:1 compression. 2.25int and 1.88ext valves. The heads have mild port work mainly on the intake exhaust just cleaned up bowl blend and valve job done. Vehicle is 3000lbs powerglide tranny for now 350 tranny later 3.73 gears 3500 stall 28x13.50 tires. Suspension works well. I need some recommendations on camshaft to help weak exhaust ports. I want a solid roller. Thks
