Hi all.
I just put a 396 in my 65 Chevelle. On the initial build and start up we lost quite a few lobes and ended up having to replace the cam. I've now read that Comp Cams are notorious for going down. I had a filter magnet that caught A LOT of the metal from the cams going down so I'm sure that helped.
We pulled the motor, took off the intake/pan and completely douched everything out with about 15 cans of brake cleaner. The bearings looked fine other than the very front bearing had a really slight score around the middle. I'm running an oil filter magnet and also a trans pan magnet on the oil pan to try and catch an add'l metal that may be floating around.
I pulled the filter last night after the initial break in oil change and there was some metal in the filter but nothing like what was there after the lobes went down.
I guess I just wanted to get some thoughts on what my chances are of this motor lasting and if something goes wrong....what I should've done differently.
Can anyone share any experience they've had with something like this?
