Bill, I've swapped a few BB Chevy camshafts while the motor was still in the car and never had to drop the pan at all. Just removed the forward-most pan bolts that thread in to the timing cover and loosened one or two bolts directly behind them. It takes a little patience, but if you take your time and then make sure you seal her back up well, you should have no problems.
