Ok Mark now what??
I followed your recommendation in another post concerning pushing out the short ball joint from my GW lower arms and found that the Howe tall ball joints that I purchased from SC&C don't fit at all. Gokou says that the GW ball joints are Moog "Problem fixer" units and as such are larger in overall diameter. Well he's right. Does Howe make a larger diameter balljoint body to fit into the GW lower arms?? I'm sitting with one arm busted down till I get an answer and the other arm I won't touch till I get an answer. I'm a bit miffed at spending $170 bucks on Howe lower balljoints that I can't even use at this point.
