1 - 20 of 24 Posts
So I started rebuilding a '79 vintage Q-Jet that was sitting for over 10 years. While disassembling I noticed the secondary butterflies weren't opening. I assumed they were gummed up so I continued the disassembly and soaking. After cleanup they were still stuck shut. I thought I would try taking off the throttle blades and isolate the problem to them being stuck or the shaft. After breaking off the first screw, I researched a tech article in QuadrajetParts and discovered I was supposed to file off the exposed end of the screws before removing. Damn. I then tried to push the blades and they appeared to flex away from the throttle body, so now I'm thinking the shaft is stuck. Before I muck up any more parts, any tips on removing the shaft without inflicting any more damage? TIA... Dan T
Heat is your friend, try to heat the casting genltly. I went thru this few months a go, be carefull.
Search out some Q-Jet builders here. Im not sure you can even get those parts from NAPA or the like anymore. Been over 25 years since I bought a Q-Jet kit.
I would be careful applying heat. I believe Q - Jets are pot metal. Im not really sure how that reacts to each other. Depending on the heat and temp of the heat. Janih did say gently.
Soaking the Q-Jet in a cleaner or mixture of cleaner for a long period of time could help. You would just have to search that out.
I'm sure we can find some parts for Don if need be.
Super Moderator
Is it the actual secondaries sticking or the air valve in the top ? I just finished for a boat one where the air valve was sticking. I had to take it apart and run a reamer through the shaft bore to clean it up.
Try soaking yours again with penetrating oil and tap on both ends of the shaft with a small hammer and see if it will break loose.
These guys are a pretty good source for parts:
If you order throttle plate screws make sure you measure yours first. There are two different sizes but they really dont tell you that in their listings.
Confirming they are the secondaries. And I did get a kit from Napa before I tore it down. Qjetparts.com is where I saw the info on filing the screws… they have really good tech articles. So regarding the screw… the head and a few threads snapped off. The remaining threads and the mushroomed portion sticking out the other side are intact and seem pretty solid. I’m thinking of just putting a drop of thread locker in the cavity vs. replacing. Yay/nay?
Super Moderator
Depend on how brave you are :) What I would do if was not replacing the screws is to put them in with a drop of red loctite then turn them over and with something solid under each screw head take a center punch and give it a good hit right to the center of each screw. Te one where the head broke off has to be replaced, why not just get all 4 new ones ? Too bad you arent closer, I have a bag of the 3-48 screws that I got from McMaster Carr years ago.
I would also say be very careful with heat. The throttle shafts have a teflon (or something) coating on them, at least the newer ones do and I wouldnt want to burn it off.
Can you get a set of small vice grips on the mushroomed section and turn the remaining screw out from the other side?
Good to see there are those still using Quadra Jets.
You got that right, the Q-jets were light years ahead of the AFB carbs for me and way easier to tune.
Super Moderator
Dan,
If you arent not in a hurry send me your address and I will throw some screws in an envelope and mail them to you.
Again, good to see there are still people around providing services and parts to what no one wants in the masses. There is a market for that stuff.
Reactions: Janih
Look How much helpful people here, this Forum feels like home. Get the Cliffs book, I have it and it is Super!
64ElcoDan : So I started rebuilding a '79 vintage Q-Jet that was sitting for over 10 years.
BTW, 1979 was one of the best to rebuild.
It may be an 800 cfm unit. Model "M4M"
Reactions: von
An angled front vent tube is always a good sign.
1 - 20 of 24 Posts
