1 - 1 of 1 Posts
How much slack in the cable at WOT? i've changed intake manifolds and the new one is slightly taller and the 'universal' cable bracket is too far away (i think) so the cable is tight at WOT. i've drilled new holes in the bracket so i can still pull about 1/8 inch cable out at WOT. is this enough or should there be a little more? it seamed to shift harder with the other manifold bracket which had about 1/4 inch extra to pull at full open.
1 - 1 of 1 Posts
