Posted this question earlier in heating and cooling but no response. Does anyone know if it's possible to lube the heating and cooling cables on my '67?? They have a plastic jacket so you can't simply spray them and they have loops on both ends so you can't remove the core (I think). Also, does anyone know what moving the heat and cold control is actually doing as I don't see a water control valve unless it's inside the heater box. Thanks!!
