Alright I have a 72 Chevelle that im building a .60 over 350 for..361 now right?
Anyways, this is how my build up is looking.
Sealed power hyper flat-tops
GM X rods
GM cast crank
Summit 3,000-6200, 234/234 Duration, .488/.488 Lift Cam
GM 305HO 416's ported mildly with stock size valves
Z28 valve springs, Summit roller tip rockers
So 10.5-1 is likely on comp. ratio, with the 60 over flat tops and 305 heads? Is this thing going to hate the taste of regular?
Now heres where I need help.
I have three intakes and i don't know which would be best.
Edelbrock performer, or a performer RPM, or a perfomer EPS?
I'm going to be running a Carter AFB 600 for right now.
Also, this chevelle had a 305 late 70's truck motor in it when i bought it...wore out bad...spun a bearing a few weeks ago.. And the rear end is a 10 bolt peg leg, and I have no idea what kind of gear it has, so I don't know what kind of stall to use.
I have a 3000-3500 stall, would I mess it up if i ran it with say the worst gear it could have...a 3.08?
I'm really excited this is the first motor I've ever built. And I'd hate to ruin a good stall
I have another converter but i have no idea on what the stall might be it's a 12" how can i find out what stall speed it is? The guy i got it from said he had it behind a built 327 and thats about all i know.
Also, is this cam I going to be about right, or is it to much?
Also what kind of power do you think I'll be making? Anyone like to make a guess?
Thanks for the help, Jensen
GM X rods
GM cast crank
