hey guys,
i own a 72 chevelle and i was wondering if there is any other place where i can get a build sheet for my car. I have one but it is rather ripped up and torn apart over the years, and some of the options are missing (i have all the good ones left over though). Is there any where i can go to get information about the options that came complete on the car from the factory? thanks
Probably the only way you will find enough info on your car to re-construct a build sheet is if your car was built in Canada--they keep records on that sort of stuff. Otherwise you should keep looking for another build sheet in your car. Have you removed the gas tank and looked on top yet?
thank's i will do that. I will check the entire car.
but what if there is no where on the car it can be found, and my car is built in the maryland factory i am pretty sure. =(
