I have found a partial build sheet in my back sheet, but wonder if there is one above the gas tank on my Baltimore built 70. Curious as to how it was placed up there for those that found one. I tried to run a light and use a mirror to see down the channels, I could see okayl. If there at all, would it be in a spot that I could see from that vantage point or really does the tank need to drop down?
Thanks,
Dave
My baltimore car had one inside the driver seat glued to the metal frame and one under the back seat.
Couldn't hurt to check the tank. My build sheet came from the top of the tank. It's not pretty but has all the info I need to prove what it is.
