I finally got my gearvendors installed (and driving) on my th350 and wanted to outline my thoughts and a few other things in order to help someone down the road.
Why a GV?:
I was already really happy with my th350. It shifts really nice, I have a really nice billet shifter for it, and the converter is pretty spot on for my combo. I really just wanted an additional gear. Obviously we know that the price point of these isnt cheap so forking over the cash for a new one wasn’t ideal for me.
I was able to find one from a member here (thanks @Stalkingbearcat) that was used for 600 dollars with all of the parts that comes in the kit. Controller, trans adapter (for a power glide), the booklet etc etc. He was having problems with it and after speaking to him in length, I decided that I thought his problems were related to the computer, not the GV unit itself. I drove damn near out to Arizona to get it and he met me at a land mark off the highway. Damn nice guy. We chatted for about 30 minutes.
Wiring:
I didn’t use the computer. I used an illuminated latching push button in the dash. You just have to remember to turn it off before coming to a stop. Very simple to wire. (Anyone reading this down the road PM me and I’ll lay it out for you).
Fitment:
I waited to install new polyurethane body mounts before installing the gearvendors. (Not harsh like some have stated. NVH isn’t bad) This gave me clearance that was badly needed. I don’t recommend installing a GV until you have new mounts under the body. My crossmember (which was already in the car) is a summit house brand that I’m pretty certain is just a rebranded G force. I also had to get a new trans mount. Energy 3.1158g. This is the low mount. I was still able to achieve optimum driveline angles by using adjustable rear upper control arms. I had to massage the trans tunnel just a little bit. Took me about 10 minutes of strategic beating. A 2lb ball peen dead blow hammer made it very easy. As expected, I had to cut my driveshaft. I cut it down to I think (from memory) 41 inches center to center U Joints. Dont take my word for it. Always measure. But that should give you an idea. Now a 3 inch shaft will have a critical speed close to 10,000 rpm. Always a huge talking point on this board with the longer shafts these cars need.
Cost:
Below is the final break down of what I paid. I had to buy an adapter for the th350. GV really has a strangle hold on the market and you really have no choice but to get it from them. If adding a GV to a th400, you can find some used ones floating around the internet, or get lucky and find one under a motorhome. So take that into consideration because that doubled the price of the project.
-Used GearVendors w/everything 600
-Adapter kit 983
-Core charge for adapter -200
-Activation Button 31
-Fuel used to pickup unit 100
-Driveshaft cut and balance (local) 140
-Trans Mount (energy suspension 3.1158G) 45
-2 lb ball peen dead blow hammer 15
-Wire, fuse holder and connectors 10
So I’m all in for 1724 dollars. If I had a power glide or got one with the right adapter, I would have been all in for under 1000. All in all I’m very happy with the install and the way the GV performs. I plan in installing a momentary button on the shifter to a latching relay down the road so I can split gears but for now I’m happy with my overdrive for 1700 bucks.
Why a GV?:
Wiring:
Fitment:
Cost:
-Adapter kit 983
