Hello, this is my first post to this site, I am about to tackle this seat and console conversion and was wondering if any could send some pictures along with instructions regarding this installation.
The car is a 72 Chevelle (w/th350) currently with Column shifter and Bench seats. I have purchased the buckets seats from a 69 GTO and the console came out of a Monte Carlo. I just ordered all the parts required to install these pieces including both wiring harnesses, shifter cable, shift conversion kit and brackets for the buckets. My questions are:
1. Mounting the console (location for rear console bracket, shifter and cable)
2. Is it correct that the front of the console get screwed directly to the floor pan?
3. Wiring harness (where does this get connected to under the dash)
4. What do I do about the seat belts on the inner side of the seats, do they remain in the same position?
5. Using the shifter conversion kit, is anything else required to be done to the linkage from the original steering column.
I hope I didn't make my first post here to winded but I just want to make sure I do this right the first time.
Thanks in advance for any help.
