Tyring to figure out what would cause this to happen.
Took the car for a spin got on it a bit I was manually shifting and all of a sudden I heard a bang kinda like I threw a rod and the car shut down.
I pulled over popped the hood and I saw that the coil wire came off the coil. After closer inspection I saw that the distributor had turned clockwise quite a bit and ripped a few boots from the wires and one of the cap clips unclipped. I pulled the cap and found the the bolt from one side of the rotor just sitting there on top of the rotr and the othe one was loose.
I then turned it over a few times to see what was going on and the distributor did not spin, if I held down the rotor with some pressure then it spun.
I towed it home and pulled the distributor and some of the gears are missing.
Besides what might have cause this will I have to tear the motor down and clean it?
Do you think it may have messed up the cam gear? It is a lunati HR with everwear gear
thanks
Bill
thanks
Bill
