I need help re-assembling My engine. Its a model 326431 type 0228-01 Code 7610061.
I need the rod bolt torque spec., the alignment spec for phasing in the balance shaft and the torque spec for the balance shaft drive gear off of the cam shaft.
Many thanks
Milan
Super Moderator
Milan,
The best thing to do is to purchase the correct service manual for your engine. Lowe's and Home Depot used to have them, any good mower shop should have them. They are only $15 or so.
The rod torque on a lot of the new ones is a "torque + angle" deal, you have to get it right.
