my hydraullic portion of the lamp does not operate because the wire leading to the proportioning valve is gone. i found one in a salvage yard off a 70' cutlass. it is tan, as i think mine should be. question..i have never "unplugged" the harness at the firewall under the brake booster. i guess it just pulls off and i need to insert the new wire terminal (wire and ends are intact) into the appropriate hole in the connector, then plug it back in? could this connector be hard to remove from the firewall, it looks like it has never been off before.
also, the warning lamp operates with the parking brake on, but is white, shouldn't this be red? it seems that the lens must be missing , if so-is it missing from the instrument cluster or the back of the black dash bezel. where could i find a new lens?
thanks for any help 70 chevelle ss
[This message has been edited by DAVID IN GA (edited 08-28-99).]
