My 67 SS BB has a distribution block (called a switch asm. in assembly manual) thats located under the master cylinder on top of the frame. It has two inputs, three outputs (1 ea. for front brakes)( 1 for the rear) plus wire for warning light. Question: can I use the block with my 4 wheel disk Brake
conversion by just putting my porportioning valve in the rear brakes line and the two new lines from new master cylinder to the inputs of the block (switch asm.)
