I noticed my brake pedal won't stay fully extended after it's released, there is play between that position and when the brakes are applied. As a result if the car is parked on a hill the brake lights will be on if I don't have the switch adjusted properly in it's bracket. It seems like the spring is weak as it will bounce in freeplay if released quickly. Also, after I stop I have to sometimes pull the pedal up with my foot to make sure the brake lights are off. It appears that this condition knocked the switch out a few times as the threads are buggered up because it can't be adjusted to the right length in the bracket (small hose clamp is on it now). This is a manual brake car, '65.
Does the spring wear out? I feel like if it had a little more tension, the brake would release completely, and stay released, actuating the switch when it should.
