I have a minor leak where the front line connects to the master cylinder. I'm assuming it is in the fitting that screws into the master cylinder. Assuming this is correct, can I use teflon tape on it to help create a seal? Or will the brake fluid eat up the teflon? If it ends up being in the line instead of the fitting, is my best option to replace the entire line?
Thanks in advance.....................Mark
