Greetings and please help! :) been happening a few times now...... after turning off engine, brake lights are staying on. I have gear vendor control, electric fan wire, and stereo wires plugged in the fuse box. tried taking each one out separately, but the brake lights won't turn off unless I take battery cable off. Any assistance is greatly appreciated.
Look on your brake pedal up at the top of it their is a little round switch with 2 wires hooked to it and it is screwed into a bracket and the push button will touch your brake pedal bracket. You need to adjust it their.
hey badss396! THANKS!! I see the prob now. the metal bracket that is supposed to touch and shut off the circuit (i may not be saying that right) is messed up. i should be able to fix it now. Thank you very much!!!!!!!!
Hey Bob!
You may need to replace the brake light switch, cheap and easy.
How is Big Red doing?
Good Luck!!! :D
