1 - 8 of 8 Posts
brake issues, what I've done and going to do, any suggestions: RESOLVED
After replacing the combination valve(the terminal was loose and on the verge of breaking) and rebleeding I still had a dash light issue. Although I bench bleed per directions there must have been air left in the rear part because when I bled at the master the light went out. And the brakes work. Will have to add additional vacuum dhe to cam because at idle the brakes aren't what thet should be. Thanks to all. Pete and Nicholas
I’m hoping someone can help me out. Here’s what’s been done and the results. Converting a 2dr, 350 automatic that had 70 power drum to power disc. Bought a “complete” 71-72? setup used. Things I used from it were the spindles, caliper brackets, dust shields, booster, combination valve and lines from master cylinder to combination valve.
Purchased master(bench bled it), new rotors, bearings, disc brake calipers and pads. Bought used disc brake frame brackets for the new rubber hoses. Also had to purchase a new brake line for the left front, got it at NAPA, nothing special and bent it to fit myself.
Cleaned up used parts and painted all parts. Installed correctly and bled system but had trouble bleeding the rears and the brake dash light stayed on. Further inspection revealed a leaking left rear wheel cylinder. Purchased two new rear wheel cylinders and replaced the old ones. Rebled the lines with the help of a mechanic friend. Still the brake dash light does not go out(will go out if you unplug at combo valve). Read all the posts on TC with the consensus being the valve needs to be re-centered. Tried the drive and hit brakes hard, no luck. Tested booster by pumping with the car off and starting and feel the brake pedal move towards the floor, tested good. I also tried the Chilton(read the procedure in their book) method of turning the key to the on position open the bleeder valve of the first bled side(rears) and had someone depress the brake slowly. According to Chilton once the dash brake light goes out tighten the bleeder screw up and release the pedal. That method did not work. Also tried another suggestion mentioned here and that was to open the bleeder had depress the brake hard and fast then tighten the bleeder back down. You got it, no good!
Took the little rubber boot off the combo valve to find the tiny(and I mean tiny) little “button”. Depressed it although it didn’t depress very well or much. Tried cleaning it with brake clean hoping to free it up. That seemed to help a little. Still the brake dash light stays on. Still not sure the valve is working right. Going to try one sent to me by a fellow TC’er tonight.
Mechanic friend came over and tried to help again and thought the booster was bad. He said it didn’t feel like the brakes were getting the “assist” they should be getting from the booster. Got a booster from NAPA only it had the long pushrod for power drums and not the short one for power discs. Due to design differences I could not swap out my pushrod for the one that came with the new booster. Hopefully they can resolve that issue shortly.
I borrowed a vacuum gage to find out at idle there is only 8-10 pounds of pressure. This is in park and not in gear(MC currently is off booster as going to try to and replace the booster). Vacuum tested the metal line coming off the intake that goes to the check valve on the booster. That line comes off a T fitting in the intake.
My main concern is getting the brakes to function properly, which means getting the dash light off. The “assist” issue is secondary and doesn’t affect the brake light, right? Two things I haven’t done that I’ve read is test to make sure front and rear brakes are working. Plan on doing that this evening. Going to jack the car up by the frame under the drivers door, put the car in neutral and have someone(daughter) apply the brakes as I spin the tires to make sure the front and rear brakes are functioning correctly. Also going to try and have someone(son) depress the “little button”(using a C-clamp on this I don’t believe will work) on the front of the combo valve and re-bleed the system. Right rear first the left rear, then right front, then left front and then have the helper(young son) release the pressure on the combo valve button. I tested the hard vacuum line that comes off the T in the intake. With the cam(no idea of specs) there is 8-10 lbs pressure that as the rpms are increased it raises as well.
A question, I just talked to NAPA and they asked what year master cylinder I had(I think 71 will check when I get home tonight). They tell me the booster is different from 70 to 71-72. They state that the booster from 67-70, is the same and changed in 701 Is this right?
I think I’ve covered it all. Any and all help would be appreciated. TIA Pete and Nicholas
no1dc,
the brake light on the dash is also for the parking brake.
make sure your parking brake is fully released and not actuating the light.
maybe even disconnect it to be sure.
david
p.s. sorry, just read that light goes out when combo valve is unplugged
pete,
one other thing you could try is to take the terminal plug out of the combo valve and manually put the "centering " pin back in the center of the valve.
reassemble and see if the light stays out.
it just might really be stuck in one direction.
david
Parking brake idea is a good one. But I would think that if that was the issue, then unplugging the combo valve would not turn of the light is the parking brake was triggering it.
I still think the valve centering is a good idea to try some more. We used to do this by opening the system at the flare fittings on the combo valve. Open the rear, depress the pedal and if that doesn't reset it try the same with one of the front lines (to switch it the other way).
You don't inadvertently have the brake calipers upside down? I had a buddy do this on a Nova, several guys looked at it before it dawned on him what was wrong. Could it be a bad master cylinder? I know it's new, but it could be internally passing fluid between the front and rear (through a damaged seal). Did something else in the rear, like a steel line or rubber hose, fail coincidentally? I had a rusty brake line on a Ford Taurus, replaced it and it promptly blew another steel line further in the system.
I agree with Zeke on this one. I have personally seen this be the problem with 4 GM vehicles. I have seen this on a: 1969 Chevelle, 1973 Impala, 1975 Chevy 3/4 ton Pickup, and a 1972 Cadillac Eldorado. The light was on, and went off when the Master Cylinder was replaced.
Also, all of these vehicles had been sitting unused for long periods of time and were fine when intially resuming driving, but the light on all of them came on within a short time of their return to the road.
If you don't have a new 71-72 style master cylinder, get one.
EDIT: I didn't read carefully enough evidently, because your Master Cylinder is new.
I don't mean to hijack, but could someone to elaborate on manually centering the valve by removing the terminal plug? Do you just take out the switch and use something that will fit down in the hole to move it forward? I am not getting any fluid out of my rear brake lines and i think that is the problem.
webfoot,
when i pulled my frame out from under and replaced EVERYTHING, i opened up my valve just so i could buff it shiny brand new.
i unscrewed the terminal plug and you can see down inside the valving that trips the light.
david
1 - 8 of 8 Posts
