Anyone know the best way to take off the brake drums on a 68 el camino without a puller
If it is not what the other suggested.Anyone know the best way to take off the brake drums on a 68 el camino without a puller
Thank youIf it is not what the other suggested.
For the rear drums, make sure that there in no rust at the ~2" diameter center pilot. Clean and put some penetrating oil on if needed. Later pull on one side and 1080 drees opposite tap with a hammer. Work the pattern around in several orientations. If needed add some more penetrating oil.
Later, at assembly wipe a small amount of wheel bearing grease at the pilot diameter before installing the drum.
