1 - 2 of 2 Posts
when i convert my chevelle from manual drum to power disc does the bake pedal need to be adjusted from its stock position also has anyone used any brake conversion kit from NPD and were there any issues with it any recommendations on the kit choice?
The position of the brake pedal will change when you install the booster. The power booster connects to the lower hole in the pedal rather than the upper hole used by the non-power system.
1 - 2 of 2 Posts
