Hello this is my first post so if it is in the wrong area I am sorry, The problem I am having is I replaced my power brake booster and no matter how much I adjust the cylinder screw that connects to the actual break pedal the brake lights do not go off - They are constantly on - and to top that off my gas gauge goes below the empty line and the turn signals on the dash light up when I turn the ignition on?? All of this started after I changed the power brake booster and reconnected the battery - It was fine before..in addition when I hold the key in a position right before ignition actually takes place(pre starter crank or turn over) the turn signal lights go off and the gas gauge reads correctly....I am very confused - I restored my chevelle years ago but never encountered anything like this and do not really have any one to contact about this - Thank you very much in advance - Aaron
