1 - 2 of 2 Posts
Hi,
Having a light poblem with my 67'Chevelle. When I put the brakes on and turn signal to the left, the right tailight goes out. The oppiste direction works fine. It also seems that the left blinker blinks alot slower then the right. I replaced the bulbs in the back and check the ones up front, no luck. Any help would be great.
Tim
Have someone turn on the signal and step on the brakes.
With the tail light still installed in the socket:
Touch the unlit bulb with one end of the wire. Touch the metal bulb base right where it meets the glass.
Touch the other end of the wire to a known good ground.
See if that make the light come on.
1 - 2 of 2 Posts
