I have 67 Chevelle, converted the front to disc brakes, put on new brake lines, Master cylinder/booster, porportioning valve and new brake cylinders on the rears. Wjem ot came time to bleed the system, no fluid to the front or rears. After two hours of pulling my hair out, I looked up Brake Bleeeding problems in the Brake and suspension forum through a search. I found several possible ways to fix the problem, but found one blog that said to bleed the front brakes first, and then the rears. After making sure that the M/C was pumping out fluid, I did this and it worked. Dont remember which member said this, but thank you....:noway:
