On my Dragster every single line was braided line/AN fittings.Use motor oil, LOTS!!! When cutting the hose to length wrap it a few times with black electrical tape right where you will be cutting it so, when you make your cut you will be going through the tape.( this will help prevent the steel braiding from fraying) Put the end you're not using in the vise close as possible to the cut mark, then use a hack saw (carefully). Also put masking tape on the AN fittings when you are connecting the line,ths will prevent yu from scratching up your expensive (and great looking) fittings. .....well thats how I did mine ,if it helps.
JoeS
"67 Malibu"
[This message has been edited by Joe454 (edited 06-14-99).]
