Steel braided hose will cost a fortune. You will need to be VERY CAREFULL when securing it to the frame, because the steel wire that makes up the outer sheath acts like a hacksaw on anything it rubs against.
I strongly advise using "hard" steel (stainless if you can afford it) tubing for 90% of the fuel line, with flexible hose only at each end, just like GM engineered it. There is no reason not to use a higher grade of hose, such as the teflon liner/steel outer braid, provided you secure it properly so it doesn't chafe on anything. Be aware that the teflon/steel braid hose is easy to kink if bent too tight, and once kinked it is TRASH even if it looks good on the outside! You CAN NOT straighten out a kinked teflon liner.
For me, however, I'm very fond of Aeroquip 332 rubber/fabric hose. Cheaper than the popular teflon/steel braid model 2807 hose, pretty blue, and if used with the matching Aeroquip barbed hose fittings, (much cheaper than the hose ends needed for the teflon/steel braid) does NOT need clamps to assure a perfect seal even with over 200 PSI.
