Another bonus of a longer stroke, besides greater displacement, is basically increasing the leverage of the crank...Kinda like when you take off a rusty bolt, it takes less effort to remove that bolt with a longer wrench (why cheater bars work ect.) In an engine, what that amounts to is greater torque at lower rpms. As with everything there's a tradeoff, in the form of higher piston speed at any given RPM = higher friction, and greater centrifugal stress on the crank at any given RPM = broken crank at high revs...
In general terms, if you want a low/mid range high torque engine go for a big stoke. If you want a high revver, keep your stroke within limits of say a 350 cid stroke. If you want both...prepare to pay for forged billet stuff in your short block.
68 El Camino...Slow, Much Work Required
98 Z28...Fast, No Work Required
Goodfellow AFB, San Angelo, TX -- Where? That's what I said..
