Can anyone recommend a video bore scope that I can put into a spark plug hole and see the piston, etc. and also see the combustion chamber of the head?
I bought 1 at Harbor Freight for 69 bucks that works real well, they have 2 different models with 2 different diameter heads, mine is the smaller diameter, about .250, easily fits in a spark plug hole.
I wanted one for the same purpose. I just googled borescope and bought a cheap one for an Android phone. Being a halfwit I couldn't think of a way to get the app from the disk to the phone so I searched and found an app. It also works from a PC. It says dbpower on it and works fine.
So you can see the cylinder walls, top of the piston clearly? Then can you see the valves and the combustion chamber?
The one I have came with a slip-on mirror that allows you to look to the side. So you could see pretty much in any direction depending on adding the mirror or not.
