Your car has come a long way. I looked at this thread when you were building it. I hadn't looked at it since you got it running. I didn't realize you went with a regular head gasket. You definitely want to go to an MLS. That's what it in mine. I sprayed straight methanol on my car also, two 15GPH nozzles. Mine would start between 130-140 and would increase about 30 degrees in 5 seconds. How big is your current cam if you only run it to 5,200? Did you run the car with this engine and no turbo? Before the Procharger mine went 6.60's in the 1/8th and 10.40's in the 1/4. What fuel are you running?Well the car is back up on the ‘hoist’ for the winter. Like every year there is a list of “to-do’s” and what not. I have come to the conclusion next year I bringing this up a competing level with a street focus. Goal is to add 300 wheel HP to the whole setup. Base motor setup is there just need a couple small additions:
-Camshaft, going as big as I can for street duty still. 6000rpm limit instead of 5-5200rpm
-Rebuild and port these AFR 305 heads
-new 1500trq rated clutch, already ordered
-3:1 clutch pedal reduction
-motor mounts, hate these solid ones
-look at IC
-aluminum exhaust (full 5”?) and brake setup
-weld up a cracked Dana 60 axle
-remove tachometer, replace with clock.
-hubcaps for the win
biggest Deal for me right now is head gaskets. Going to move from a composite fel Pro head gasket to a MLS style.
Wife let me know she’s wants to be in the “heavy hitter” line next year!
my intake temps don’t rise above 110f. I use meth more for deto suppression. Right now I am on pump and will keep it on pump for simplicity. Current cam is a zz502 (224/233 @ .050, smaller than most SBC) so there is a lot for improvement there. Keep in mind this is a street car with a manual transmission. Best so far is a 6.60, no 2 step or boost builder. Still run a fully synchronized trans. Goal moving forward iS a 6.0 average on a drag n drive event, pump gas deal.Your car has come a long way. I looked at this thread when you were building it. I hadn't looked at it since you got it running. I didn't realize you went with a regular head gasket. You definitely want to go to an MLS. That's what it in mine. I sprayed straight methanol on my car also, two 15GPH nozzles. Mine would start between 130-140 and would increase about 30 degrees in 5 seconds. How big is your current cam if you only run it to 5,200? Did you run the car with this engine and no turbo? Before the Procharger mine went 6.60's in the 1/8th and 10.40's in the 1/4. What fuel are you running?
My F2 is too big to run in reverse so that the intake faces forward. It pulls air from over the headers so the air starts out hot before it's even compressed. I recently cut about a 12" section out of the inner fender to allow more air and I moved the blower out and down. Your cam is real small for a 540. I'd lean more toward 245+ on the duration but that's me. I hope to do a drag n drive event next year. I've got a flex fuel sensor that I need to install. Then I can run pump gas if E85 isn't available.my intake temps don’t rise above 110f. I use meth more for deto suppression. Right now I am on pump and will keep it on pump for simplicity. Current cam is a zz502 (224/233 @ .050, smaller than most SBC) so there is a lot for improvement there. Keep in mind this is a street car with a manual transmission. Best so far is a 6.60, no 2 step or boost builder. Still run a fully synchronized trans. Goal moving forward iS a 6.0 average on a drag n drive event, pump gas deal.
camshaft I am thinking of somewhere between 235-245 durations @ .050 should be a good deal
80% street, 15% drag n drive, 5% drag.I'm sorry it's been awhile since I read through your build. What are your plans with the car? Strictly street or occasionally do you plan to take it to the track? My car was built for mostly street with an emphasis on the track when I do take it there. My car came with a stick and I was going to stay with that. Unfortunately, reality hit me like it did back in the early 80's. It's fun to row the gears but for consistent straight line performance you can't beat an automatic.
I went for years without a bar or cage and the car was running 10.40's back then. All I had was a lap belt, jacket and a helmet. I feel much better about running the car at the track now after I put a 10 point cage in. I've got a swing out bar on my side. I need to put one in on the passenger side so my wife doesn't have to climb over.80% street, 15% drag n drive, 5% drag.
I collect most of my miles on drag n drive events, I usually go for 2 in a summer. That said I go for fun and not competitively as I don’t want a roll cage in the car. Car is fully capable, after this winter, of low 9’s on pump gas, but me and the family cruise town a lot as well. Thinking about a 5pt roll bar, haven’t convinced myself yet.
