Hello..
1967, 396 motor, quadrajet carb, 4spd, points IGN.
This is my first post (and only just got the car) so hopefully not jumping the gun asking questions. But in anycase curious of what I should look into having this problem.
Leaving the line. getting on the gas hard car has power then bogs then power then bogs off and on. Seems to not bog at higher speeds at WOT (so talking RPM's above 3500 seems ok)..
Has a quadra jet carb so been tinkering with the secondary spring. adjusting that does not seem to effect the problem. So I'm starting to think about the ignition. (not knowing if the points are adjusted correctly although I'm also thinking of upgrading that part)..
Need to check where the timing is set. (wondering what is typical for a 396) But car drives fine other wise so thinking the timing is set ok in anycase.
Still have to check the plugs.. And installed a O2 sensor so I could watch. Seems to peg to the rich side before it stumbles when this goes on (but again probably need to observe a little more)
Seems to have plenty of power and pep outside of this bog area..
Hopefully will not have to take to deep a dive to get things a little better.
b.
b.
