Hello,
I am in the process of refreshing a 1972 Chevelle and need some advise.
I'm tackling this my self so any input is greatly appreciated.
When standing behind the car to get a good look at the lines of the body, I notice that the contour is not crisp or sharp. Obviously this needs to be re sanded and filled. I tried sanding this to see how it would go but quickly realized that I only create more valleys or uneven areas.
What should I use to sand these large areas or rear side panels. That small sanding block is not working. Any of you have the same headache?
What did you end up using as a sanding block?
Thanks,
JR
Thanks,
JR
