When I removed the body of my 64 from the frame, one of the body bolts, I guess the cage nut broke. So I just ground the head off. Well now I was wondering the right way to get to that nut so I can fix it. It is one or the rear bolts under the trunk.
Which one is it? Either way, you're going to have to cut an access hole in the trunk pan. Don't do it sloppy, make a nice U shaped cut so you can bend the metal out of the way to remove the nut. When your nut is back in the cage, you can bend the metal back in place & weld it up like it never happened.
Related Threads
Team Chevelle
5.1M posts
115.6K members
Since 1998
