Wasnt sure if this should go here or under bodyshop. The recommendation wasngiven that before i go cutting the quarter off the car ther are some prerequisites recommended obe of which is body mount bushings. Clearly from 2 of the pictures they need it. So i had a three questions. The second picture that bushing doesnt look half bad. It is located midway under the door. It doesnt appear to have a bolt through it or even a hole to do so. It appears it just rested in there. Is that normal? The second and more importantly with how flat the radiator core support bushing is and such, how off will the geometry of the door, fender, and quarter be once they are changed? Should i go ahead and remove the fenders to be safe?
Thanks, Big D
Thanks, Big D
