Hi Guys
been gone for a while. Now I'm back with a problem. Appreciate your help please.
I think I blew a head gasket. I'm not sure. I was driving on the street when I opened the throttle and it happened. I saw smoke blowing out the exhaust. I pulled over and saw coolant dripping out from what appeared to be between the cylinder head and the block, and dripping onto the header and causing smoke. There was also smoke coming from the combustion chambers - blowing out the exhaust piping.
I removed the head and took a look. The gasket "appears" to be in very good condition - no visible problems. It's a Felpro PermaTorque. It only has about 1000 miles on it, maybe 2 years old since the rebuild.
I don't know what to do now. Everything looks fine. I can't just throw it back together and hope it's ok. What should I do?
I'm 95% sure it was NOT the intake manifold gasket in case your wondering.
One more thing I want to add. The crankcase had lots of coolant in there. So whatever the problem is, it caused "external" leakage onto the header, and internal leaking into the cylinder(s) and crankcase. This was a "bad" leak. As I said, the gasket appears to be normal. Now I'm thinking the head is cracked.
Lee
Lee
