Hey all,
Do anybody know the correct procedure for installing a new blower fan motor. I need replace mine and I can't find the procedure in any of the manuals I have. Don't think I even know where its located.
Corey
I did mine on a 70 Chevelle, with A/C. So this relates to that year.
Disconnect battery (safety thing)
Remove almost all bolts holding Right inner fender well leaving one or 2 in the front loosely connected.
Pull fender well down and block it with piece of wood.
You should see motor, and there are 3 bolts to loosen. There is a 2 wire connect mouted to the motor as well as a cooling tube that redirects air back to cool the motor.
Anyway, I bought a new motor from local parts store for $20.00 or so.
When you get motor out, you might have a heck of a time clearing the squirl cage/motor assemble thru the space between fender and well.
Remove cage from old motor, and install it the same way on the new motor. Install in reverse of disassembly.
Check a few things before you jerk the motor. Make sure you are getting 12+ to hi speed relay on firewall (only for hi-speed), you can check to see if there is 12+ coming to fan switch, and that the switch is not intermittant like mine still is by wiggling it.
Hope that helps.
http://www.wright.edu/~s001dga/chevy.htm
