If it’s of the LS architecture, then isn’t it an LS?I wish everyone would stop calling every GM small block made after 2000 an LS. They are not magic engines. Put a first gen small block together with comparable compression, heads, and roller cam and you will get the same results.
Unless you have a need to boost it, which a digital engine can do best, have a pro like Vortecpro build you a 600 ft lbs ground pounder. Also those digital controls may be economical if you dive it more than 5K a year, same with OD. ( although I just visited UT with its 75 and sometimes 80 mph posted speed limits and there an OD may be required just to not get run over! )1969 Chevelle SS with a frame off about complete. Would you go Stock or LS? The car has lots of new metal. Almost everything replaced. I do not have the original block.
I have the original TH400
Why so?One vote for a V6...
(Although if I did it again I’d go with a straight 6)
If it wasn't an original SS car, my answer would have been for the LSIt's nice to see a lot of BBC fans here.
I was half kidding but I’ve been reading about some pretty healthy (for what they are) 292 in-line 6’s Lately. Their torque comes in real low rpm unlike my V6. Adapt port fuel injection, a 6 speed trans.Why so?
Honestly yes, I agree with this. In today's world with what I know now, I would likely go with a big inch small block versus a big block now. I love the 489 in my car but it is large and heavy!It's crazy how many don't even consider the good old tried and true small block. It's small, light, can make a ton of power and aftermarket support is outstanding. I agree, if the car is an original BBC car I think it should have a big block. That's what I did with my SS396 El Camino. The original engine was gone so I put a 454 in it. This was 20 years ago before the 496 got real easy and popular to build. Now I'd do a 496. The LS is a great engine but so is the old small block. It comes down to budget and what parts you might already have.
I chose to buy a Sniper throttle body for my 496 BB because it's less troublesome than having to change the intake manifold and possibly the air cleaner. What I liked about the Sniper throttle body is that it bolts right in place of the carburetor, all linkages are supposed to be a direct fit as well as my billet air cleaner. The biggest part will be to install a return line and put a pump inside the tank.edelbrock proflo efi for the big block if you want port injection, or you have your various throttle body systems. As far as fuel mileage they all get about the same when you’re making good power, my car with the 454 and the sniper, for the short time it ran well, averaged 16mpg in my normal driving. The Z I use to have made 600whp with its head/cam LS7 and it wasn’t all that pleasant to drive on the street. Doable, yes, but didn’t have the manners of the big block that make about 50hp less in that configuration to the tire.
I couldn't care less about how many cubes my engine has. What matters most to me is that just as long as it's ''user friendly'', it idles good and has plenty of power for my needs, I'm happy.BBC, More cubes the merrier, no replacement for displacement![]()
Nothing sounds like a big block. IMO
I hope it works out for you. I had a sniper on mine, it was a pile of garbage. ECU failures are common, injectors failing is common, injectors come unplugged because they’re pressure fit and not clipped in place. Holley knows about the ecu and injector failures and haven’t done anything about it since the sniper was released.I chose to buy a Sniper throttle body for my 496 BB because it's less troublesome than having to change the intake manifold and possibly the air cleaner. What I liked about the Sniper throttle body is that it bolts right in place of the carburetor, all linkages are supposed to be a direct fit as well as my billet air cleaner. The biggest part will be to install a return line and put a pump inside the tank.
and
and
Claude.![]()
