Could someone give me some info on these big block heads. 3964290/3964280 E 11 70 They are on a 454 in a car I just bought with receipts for $750. I know they were cast may 70 but just wanted the good,bad, or ugly. Thanx
from motec:
69-70 oval closed 396, 402, 427, 454, 101cc chamber large or small hex plug
I'd argue they are among the best in closed chamber oval port heads. With 2.19/1.88" valves, minor pocket porting, and valve unshrouding in the chambers, these heads can really shine. I had a pair and after I had them all said and done the chambers were actually in the 109-110cc range, but still way less than 119-122cc of open chamber heads. Plus closed chamber heads have the added advantage of more quench area.
my speed pro book said there 97.4 cc's
I've had more than a few bone-stock sets and none of them measured any less than 105cc. None of the catalogs or casting books I have seen have any actual test numbers for Mark IV BBC heads. They are all just going by what GM published when the heads were produced or what someone else has said.
They were represented to the buyer as 98cc . Is a lower or higher cc # more desirable? My dad used to preach to me " never be so smart you can"t learn". Thanx guys. John
It all depends on the rest of your combo. If you have flat top pistons, for example, or a small dome piston, you would want a smaller chamber to get your comp.ratio up a bit, like maybe 9.5 or 10/1... The mid to late 60's heads were closed chamber, like the ones you have...they were between 96 or 97cc, and maybe 107cc. Then they developed the open chamber heads, which are supposed to run 'cleaner', and it's reported they flow better, but you will find lots of arguments on that matter:p ..Anyhow, those were 188cc or a little bigger. So, to build decent c/r with those, you would need a much larger dome type piston. So, it all depends on what you want. You cant run just any piston with closed chamber heads, because of the shape of the chamber. Flat tops are OK, and they make a variety of dome pistons for those heads as well. Keep em, as Cable said, they are very good heads.
Oh, and your Dad sounds like a very smart guy:thumbsup:
