I have a 66' coupe with a 402ci and a Harrison 4 core radiator. I currently have an aftermarket 5 blade aluminum flex fan that I want to remove the flex fan and use an original 4 blade steel fan. Will useing my original 4 blade steel fan with a fan shroud be enough to cool the car?
Also, is there a spacer between the 4 blade steel fan and the water pump? Or does the fan bolt directly to the water pump?
As always, thanks for your help (and education)!
Tod :beers:
Tod :beers:
