The fans are the Durale thin line they are like 2.5 inches deep. They draw about 15 amps each and I have the Durale controller also. The flat shroud work on the electric there as it pulls through (plus there are 2 I do have the pressure flaps on bottom for higher speeds) yours the fan needs to be more inside the shroud. The blades need to be halfway into the shroud so you need to pull yours out (make a bigger box) and 1-2 inches.
